![]() | Home > Faults & Fixes > Suspension fault C1A20-64 - how to fix |
cossiedave Member Since: 20 Jun 2012 Location: lancaster Posts: 882 ![]() ![]() ![]() |
pm sent |
wings21660 Member Since: 11 Feb 2015 Location: Gretna Posts: 65 ![]() ![]() ![]() |
Mine was like yours Mick so I printed off the way Ignas described it. Showed it to the mechanic then ordered the parts job done |
fordyboi Member Since: 10 Aug 2015 Location: norfolk Posts: 15 ![]() ![]() ![]() |
hi mate just done the soapy solution spray test and its just as you say leaking from in between the hoses .
Hi pal you need to look up a guy called gruodiz from Lithuania in faults and fixes he'll sell you the kit |
Gilly1 Member Since: 29 May 2015 Location: Somerset Posts: 203 ![]() ![]() ![]() |
hi gruodiz, I've pmd you but thought I'd drop a reply on here also, do you still supply the compressor covers as I would like to purchase 1 from you, regards lee. |
Just fitted a similar part to this today i managed to find a part on ebay the same as the original but metal .this is an awesome fix and solved it, also only took 30mins if you struggle to source a part they are on ebay gilly. Awesome write up though cudnt have fixed so cheap without this |
Cool, thanks fordyboi, have you got link or item number for the part, if I get the same one I no it's correct as yours is now fitted, 😀 not got a issue as yet but thought I'd be prepared as sounds like it's a part needed sooner or later, not had the sport that long but couple little issues, 1) rear wiper not wiping but motor working ( took motor apart and found warn plastic cog ordered one from eBay hopefully sort it) 2) 2 pdc sensors on rear 1 on front (replaced job done) 3) now got temperamental osf door latch ( next job fitting that thanks to (I think Ian) who posted a good how 2) thanks again for reply. |
Hi bud yh the Item number eBay Item No. 171694006022 |
jammin Member Since: 19 Feb 2015 Location: west midlands Posts: 11 ![]() ![]() ![]() |
superb nice upgrade will shout you if i ever need it sorting,,,, |
Awesome thanks mate, sorry to be pain but what's the extra hole for, the factory 1 has got 6 torx holes but there is 7 on eBay |
Not actually sure what thats for bud but it doesnt effect anything so all good . |
Cool, got 1 ordered thought might as well do it as probably does leak slightly but if not its done anyway. |
Imy Member Since: 08 Nov 2015 Location: Birmingham Posts: 3 ![]() ![]() ![]() |
on my mechanic's machine it just reads c1a20.....will the cover fix the issue with the suspension fault
lionthecatt Member Since: 28 Apr 2007 Location: SUSSEX Posts: 9 ![]() ![]() ![]() |
Hi are you still supplying this excellent piece of kit. I have a 08 model RR Sport. |
