Home > In Car Electronics > USB/MP3 playing options
micalee
United Kingdom 2007 Range Rover Sport TDV8 HSE Stornoway Grey
having come from a Jaguar XF, I had an iPod/USB Auxiliary Input box in my centre console which allowed me to plug in a USB stick with music on it and play direct through car sound system.
I do not have this box in my RRS but ultimately want to play my USB memory stick music. what are my options?
1. New Stereo which has USB facility?
2. Install an iPod/USB Auxillery Input box if possible?
3. Aux Socket (tried iPod shuffle on that with generic lead and had to turn volume up twice the normal setting and was hissing)
I don't want to spend the earth but do miss using USB sticks to play music
Post #447941 Fri Jan 09 2015 2:52pm
Bodsy
Site Sponsor
You need the Audio Connectivity Module. Around £270 from LR.
Gives you USB port, IPOD connection as well as phono audio connection. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #447942 Fri Jan 09 2015 3:02pm
micalee
Once this is installed (plug and play presumably) it would perform the same as my jag one?
My jag one looked like this http://images.pistonheads.com/nimg/25922/H...3_08-L.jpg
Post #447943 Fri Jan 09 2015 3:04pm
Bodsy
Site Sponsor
I don't know how your jag one worked, but mine charges my iphone (4s) and plays the music through it. When not connected, it will default to playing the USB stick.
I can move forward through the tracks with the steering wheel controls. If you want to scroll through tracks or select play lists, you have to do that through the ipod.
I've also recently got a iLayern BT Connector for it which works really well. But of course you cant charge through BT! Bodsys Brake Bible
See it HERE
Post #447945 Fri Jan 09 2015 3:12pm
Bodsy
Site Sponsor
fits in the glove box. Thumbs Up Bodsys Brake Bible
See it HERE
Post #447946 Fri Jan 09 2015 3:13pm
micalee
Thanks for the advice. All I am interested in is playing music via USB - does it look similar to Jag one? in as much as it has a USB slot? any pictures?
Post #447947 Fri Jan 09 2015 3:15pm
Bodsy
Site Sponsor
It has only one USB slot, it separately has a 30pin Apple connector which can be positioned anywhere the cable will reach to. (I have mine in the lower ashtray area (not that I have an ashtray))
I'll try to take a pic when I finish work. Thumbs Up Bodsys Brake Bible
See it HERE
Post #447948 Fri Jan 09 2015 3:18pm
micalee
Picture would be great thanks Bodsy - is this a main dealer purchase only? and is it easy to install? thanks for your time
Post #447949 Fri Jan 09 2015 3:24pm
Bodsy
Site Sponsor
VPLFE0002 for D3/RRS/FL2
About £270ish
Connects to the connectors on the back of the radio head unit.
Toughest bit is getting the top inner glovebox out. Bodsys Brake Bible
See it HERE
Post #447950 Fri Jan 09 2015 3:46pm
micalee
Thanks Bodsy for the extra info - any pics of yours would be great. Thanks
Post #448019 Sat Jan 10 2015 9:23am
Bodsy
Site Sponsor
Quick pic. Sub left and phono right. Fixed inside glove box upper. Could be fixed elsewhere if you prefer. Thumbs Up
 Bodsys Brake Bible
See it HERE
Post #448021 Sat Jan 10 2015 9:50am
micalee
Cool - thanks Bodsy its appreciated. Do you know if these can be purchased anywhere else other than Land Rover?
Post #448022 Sat Jan 10 2015 10:00am
Hi
Sold one of these kits to a member not long back. Not 100% sure but I think you will find they are re-branded Dension Kits as I bought a couple of leads for it from them and the L/R Kit was identical to a one they had on there Website.
Not sure if they do it any more as may be obsolete, but may be worth checking out there site www.dension.com as they may have what you are looking for.
Post #448025 Sat Jan 10 2015 11:18am
micalee
Cheers Col - Ill take a look at that also plus enquire at Land Rover direct
Post #448027 Sat Jan 10 2015 11:27am
simbad111
Hi bodsy when the VPLFE0002 is installed can you connect a usb stick or just I pod, also can you display tracks and artwork on the cars touch screen when its connected,
regards
Post #448050 Sat Jan 10 2015 3:58pm
