Home > In Car Electronics > USB/MP3 playing options |
You need the Audio Connectivity Module. Around £270 from LR.
Fri Jan 09 2015 3:02pm |
micalee Member Since: 24 Apr 2014 Location: Warwickshire s Posts: 241 |
Once this is installed (plug and play presumably) it would perform the same as my jag one?
Fri Jan 09 2015 3:04pm |
I don't know how your jag one worked, but mine charges my iphone (4s) and plays the music through it. When not connected, it will default to playing the USB stick.
Fri Jan 09 2015 3:12pm |
fits in the glove box. Bodsys Brake Bible
Fri Jan 09 2015 3:13pm |
Thanks for the advice. All I am interested in is playing music via USB - does it look similar to Jag one? in as much as it has a USB slot? any pictures? |
Fri Jan 09 2015 3:15pm |
It has only one USB slot, it separately has a 30pin Apple connector which can be positioned anywhere the cable will reach to. (I have mine in the lower ashtray area (not that I have an ashtray))
Fri Jan 09 2015 3:18pm |
Picture would be great thanks Bodsy - is this a main dealer purchase only? and is it easy to install? thanks for your time |
Fri Jan 09 2015 3:24pm |
VPLFE0002 for D3/RRS/FL2
Fri Jan 09 2015 3:46pm |
Thanks Bodsy for the extra info - any pics of yours would be great. Thanks |
Sat Jan 10 2015 9:23am |
Quick pic. Sub left and phono right. Fixed inside glove box upper. Could be fixed elsewhere if you prefer.
Sat Jan 10 2015 9:50am |
Cool - thanks Bodsy its appreciated. Do you know if these can be purchased anywhere else other than Land Rover? |
Sat Jan 10 2015 10:00am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4967 |
Hi
Sat Jan 10 2015 11:18am |
Cheers Col - Ill take a look at that also plus enquire at Land Rover direct |
Sat Jan 10 2015 11:27am |
simbad111 Member Since: 10 Feb 2014 Location: wolverhampton Posts: 114 |
Hi bodsy when the VPLFE0002 is installed can you connect a usb stick or just I pod, also can you display tracks and artwork on the cars touch screen when its connected,
Sat Jan 10 2015 3:58pm |
