Home > Technical > 2005 RRS 2.7 Diesel self revving |
AddPart Member Since: 04 Aug 2013 Location: Kent Posts: 11 |
Hi all I have trawled the old posts and can't see an answer to this problem.
Sun Nov 23 2014 12:39am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4411 |
Does it do this when you give it a rev?
Sun Nov 23 2014 6:29am |
Hi thanks for replying, yes if you blip the throttle sometimes it can provoke it into doing its party trick. |
Sun Nov 23 2014 7:46am |
Oil temperature sensor at a guess. If you looked at the live values, it probably shows -30 or similar. Bodsys Brake Bible
Sun Nov 23 2014 8:01am |
hi thank you for your reply, I will get the code reader on and confirm that. Any idea where the sensor is located?
Sun Nov 23 2014 8:10am |
My vid was of my own car with a faulty oil temp sensor. Was not nice to drive like that
Sun Nov 23 2014 8:23am |
Thanks for your help I will give the sensor a try its not a bad price. It's due an oil change soon anyway so I will do that at the same time. I will come back and let you know if this fixes it |
Sun Nov 23 2014 8:42am |
Thank you to everyone who offered help and advice.
Wed Nov 26 2014 11:42pm |
Still fixed so far and driving better than it has in ages.
Sun Nov 30 2014 11:30pm |
Are you sure the odd clunk is not just the drivers seat moving, this can fool you into thinking its a transmission clunk when you pull away. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Mon Dec 01 2014 9:06am |
It doesn't hurt to replace the fluid, I did my one with a modified sump and filter at the same time.
Mon Dec 22 2014 3:59am |
Simon58 Member Since: 01 Jun 2012 Location: Wiltshire Posts: 89 |
I shall be getting Geoff to do it in January About to get into a sport |
Mon Dec 22 2014 7:52pm |
kozzone Member Since: 26 Feb 2015 Location: Vaasa Posts: 21 |
Hello,
Sun Jan 10 2016 3:19pm |
