![]() | Home > Technical > 2005 RRS 2.7 Diesel self revving |
AddPart Member Since: 04 Aug 2013 Location: Kent Posts: 11 ![]() ![]() |
Hi all I have trawled the old posts and can't see an answer to this problem.
Does it do this when you give it a rev?
Hi thanks for replying, yes if you blip the throttle sometimes it can provoke it into doing its party trick. |
Oil temperature sensor at a guess. If you looked at the live values, it probably shows -30 or similar. |
hi thank you for your reply, I will get the code reader on and confirm that. Any idea where the sensor is located?
My vid was of my own car with a faulty oil temp sensor. Was not nice to drive like that
Thanks for your help I will give the sensor a try its not a bad price. It's due an oil change soon anyway so I will do that at the same time. I will come back and let you know if this fixes it |
Thank you to everyone who offered help and advice.
Still fixed so far and driving better than it has in ages.
Are you sure the odd clunk is not just the drivers seat moving, this can fool you into thinking its a transmission clunk when you pull away. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
It doesn't hurt to replace the fluid, I did my one with a modified sump and filter at the same time.
Simon58 Member Since: 01 Jun 2012 Location: Wiltshire Posts: 89 ![]() ![]() ![]() |
I shall be getting Geoff to do it in January |
kozzone Member Since: 26 Feb 2015 Location: Vaasa Posts: 21 ![]() ![]() ![]() |
Hello,
