![]() | Home > General > looking for some advice if anyone can assist |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
Bushes and drop links lower wish bones and upper are known to wear fairly quickly I'm afraid. 2.5 tonnes of metal sitting on all that rubber |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9017 ![]() ![]() ![]() |
It's got to be worth going back to them - after all, if you'd known that info before handing over your money you might have taken a different approach to your haggling. 2012 SDV6 - it's missing a couple of cylinders
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 ![]() ![]() ![]() |
It is a common issue, but worn bushes are classed as wear and tear, so it's pot luck if they pay out under warranty or not |
steelmen91 Member Since: 25 Aug 2014 Location: lanarkshire Posts: 15 ![]() ![]() |
thanks for all the feedback, it does beg the question though as to which moving parts fall under wear and tear and which ones dont? |
