Home > General > looking for some advice if anyone can assist
steelmen91
Scotland
Hi All,
I just bought a MY10 RRS with 40,000 miles on the clock. I bought it from an approved Land Rover dealer in Glasgow and they got it MOT'd prior to me picking it up. Now I have it the advisory notes with the MOT says both front lower and both rear upper suspension arms have slight play in front ball joint and rear pin/bush.
For a car with only 40,000 miles on it I find this a bit alarming, can anyone tell me if this is a common issue or even if this is something you would expect the dealer to fix? I do have 2 years Land Rover warranty with the car, so would this type of fault if it gets worse be covered?
thanks in advance for any advice you experienced owners can provide
Post #442729 Sun Nov 16 2014 3:50pm
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
Bushes and drop links lower wish bones and upper are known to wear fairly quickly I'm afraid. 2.5 tonnes of metal sitting on all that rubber Shocked
I would say depends on driving style road conditions but 40k is probably average for them to start to show wear and knocking. Easy fixes for the bushes but I don't think Land Rover will cover as they say wear and tear. Rolling Eyes
Post #442733 Sun Nov 16 2014 4:37pm
It's got to be worth going back to them - after all, if you'd known that info before handing over your money you might have taken a different approach to your haggling. 2012 SDV6 - it's missing a couple of cylinders
Post #442739 Sun Nov 16 2014 6:42pm
Disco_Mikey
It is a common issue, but worn bushes are classed as wear and tear, so it's pot luck if they pay out under warranty or not Sad
Post #442752 Sun Nov 16 2014 7:39pm
steelmen91
Scotland
thanks for all the feedback, it does beg the question though as to which moving parts fall under wear and tear and which ones dont? Confused
Post #442954 Tue Nov 18 2014 7:20pm
