Home > Faults & Fixes > Fixed the leaking air bag strut, now all going down instead
szki49
Wales 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Hi folks,
Looking for a little help hopefully. I had the dreaded air bag rear suspension leak and it was going down rear right to the bump stops if left for a few days. Have fitted a new Delphi replacement strut - 3 bolts on top one air fitting and 1 bottom bolt, seemed pretty straight forward nice easy change and now it is staying level.
However coming out this morning it looked like it was in access mode, as in it was far lower than usual (but level)
Is there anything that needs to be reset or recalibrated after replacing an airbag ?
Its strange that it looks like there is still a possible leak but maybe this time all round?
Any info or tips what to check would be greatly appreciated.
TIA
Post #440172 Wed Oct 22 2014 7:35am
Bodsy
Site Sponsor
Set it at your normal height and then before you lock up for the night, remove the suspension fuse (in the engine bay fusebox). That will stop it from self levelling. If it goes down, you know that there is a further leak, usually the valve blocks (one at front and rear and a centre one) if it's not pipework joints etc. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #440175 Wed Oct 22 2014 9:21am
szki49
Thank you for the info, and so quick too.
Will try that tonight, much appreciated
Post #440176 Wed Oct 22 2014 9:33am
szki49
ive just been out to check in works car park and the suspect rear driver side is again down,
any ideas what to check next ? the air bag Is new and I thought that would've solved it due to it being just one side
TIA
Post #440203 Wed Oct 22 2014 4:41pm
Bodsy
Site Sponsor
Have you tried this?
 Bodsys Brake Bible
See it HERE
Post #440214 Wed Oct 22 2014 7:34pm
Disco_Mikey
As Ian says, that is the only way to determine an air leak.
You have replaced the bag, which should.eliminate that. You then have to isolate each part of the system in turn to see where the leak is Thumbs Up
Post #440216 Wed Oct 22 2014 7:53pm
drdelrrs
Put or spray some washing-up liquid on the joints you disturbed and check they're all airtight. If so work back the system on each joint, pump and check pipework for chaffing.
Post #440273 Thu Oct 23 2014 1:30pm
szki49
Pulled the relay out.... Waiting game Smile
Post #440452 Sat Oct 25 2014 8:14pm
szki49
After 24 the whole truck has settled lower with the suspension relay out. It hasn't gone lower on the rear right this time it's all square.
Myriad the fairy on the airbag joint of the bag I changed- could I have both a sensor issue that's sending the rear right down but also it's still leaking with the relay out so a leak be present somewhere Sad
Post #440482 Sun Oct 26 2014 10:49am
Disco_Mikey
The relay doesn't provide the ECU with power, only for the compressor.
As Ian says, you need to remove the fuse, or disconnect the battery to kill the power supply.to the suspension ECU
Post #440484 Sun Oct 26 2014 10:53am
szki49
Thank you that will be tonight's new attempt--- 👍👍
Post #440495 Sun Oct 26 2014 12:40pm
szki49
I pulled the fuse this time- (F26 If I remember right) and this morning it was only down on the rear right the side that was always the worst. The rest had held itself up, which looks like it hasn't tried to level (as the lack of fuse wouldn't allow it)
Would this point to leaking air still?
Post #440611 Mon Oct 27 2014 2:36pm
Disco_Mikey
You have an air leak in that corner, or the pipework to that corner, or a leaky valve block
Post #440627 Mon Oct 27 2014 4:36pm
szki49
Great thank you. Is it easy enough to get to the block? So I need to remove anything to get at it?
I can get it on a ramp at my mates then try the fairy on all joints.
Post #440640 Mon Oct 27 2014 6:26pm
The rear valve block is on the front face of the rear N/S suspension turret. You just need to remove the wheel. Also, remove the spare to give you another approach route. It's about £100 for a new one. Make sure you get the correct one - the front and rear valve blocks look the same but they aren't the same. 2012 SDV6 - it's missing a couple of cylinders
Post #440655 Mon Oct 27 2014 7:24pm
