![]() | Home > Faults & Fixes > Fixed the leaking air bag strut, now all going down instead |
szki49 Member Since: 22 Oct 2014 Location: South Posts: 12 ![]() ![]() ![]() |
Is it a case it can be repaired with seal replacements or ain't it worth it? |
ziglo Member Since: 20 Feb 2015 Location: channel islands Posts: 19 ![]() ![]() |
Hello szki49 my Range Rover has the same issue as yours but on the front right it drops rather than back did changing the airblock work for you ? and is the airblock the same thing as the crossover link ? cheers |
it was the crossover valve about £90 changed that and sorted it. |
