Home > Faults & Fixes > Fixed the leaking air bag strut, now all going down instead
szki49
Wales 2007 Range Rover Sport TDV8 HSE Stornoway Grey
Is it a case it can be repaired with seal replacements or ain't it worth it?
Post #440673 Mon Oct 27 2014 8:15pm
szki49
I've had a good look round pipes and the pipe connection to the new air bag doesn't seem to screw in nicely. But fine on the
Old bag. Does the bush need changing when a new bag is fitted anyone know ?
Post #441859 Fri Nov 07 2014 3:54pm
ziglo
Hello szki49 my Range Rover has the same issue as yours but on the front right it drops rather than back did changing the airblock work for you ? and is the airblock the same thing as the crossover link ? cheers
Post #455596 Wed Mar 11 2015 10:12pm
szki49
it was the crossover valve about £90 changed that and sorted it.
Post #468661 Sun Jul 26 2015 8:09pm
