![]() | Home > Technical > Steering Wheel Adjustment |
I'd check your fuses first, look in your workshop manual to see which fuse you need to check. Other than that, i really can't suggest anything else other than a trip to a specalist. |
ABSport Member Since: 14 Aug 2014 Location: Plymouth Posts: 698 ![]() ![]() ![]() |
I have a 2012 RRS Steering rack column complete with electric height and reach adjustment. If you are interested. PM me. |
Ian.H Member Since: 04 Oct 2014 Location: England Posts: 180 ![]() ![]() ![]() |
Mine has just stopped (after 4 days of ownership on a 58 plate). It's going back to Saxtons to get resolved hopefully this week.. if I find out anything, I'll post it here. On the phone, they said something about "syncing". I put the key in, jumped out, pushed the driver's seat all the way forward and it started working...... for about 10 mins, so there's obviously some kind of electrical issue (tried with both keys and neither works currently). Cheers.. Ian |
vin297 Member Since: 19 Oct 2013 Location: Harrow Posts: 49 ![]() ![]() ![]() |
Hi Ian,
Hi mate..
Hi,
Well mine should be going back tomorrow to get looked at, but not holding my breath (that's a separate issue I'll address on here once I do finally get things resolved) so currently still at a loss as to what any of it could be. I've checked the fuses and none seem to be blown, so I "fear" that it's something deeper into the system.
Hi mate..
DorsetJag Member Since: 20 Oct 2024 Location: Poole Posts: 8 ![]() ![]() ![]() |
Reviving old topic...
Correction. Although the memory function works the convenience feature doesn't. I think I need to check if it's been switched off in CCD |
