Home > Technical > Steering Wheel Adjustment
vin297
United Kingdom 2007 Range Rover Sport TDV8 HSE Zermatt Silver
I can no longer adjust my steering wheel, I have tried it on both settings but it just wont move, it also doesn't move up when I take the key out of the ignition, any advice appreciated..
Post #439888 Sun Oct 19 2014 7:42am
I'd check your fuses first, look in your workshop manual to see which fuse you need to check. Other than that, i really can't suggest anything else other than a trip to a specalist.
Post #439938 Sun Oct 19 2014 6:29pm
ABSport
United Kingdom 2011 Range Rover Sport 3.0 TDV6 Autobiography Santorini Black
I have a 2012 RRS Steering rack column complete with electric height and reach adjustment. If you are interested. PM me.
Post #439959 Mon Oct 20 2014 2:07am
Ian.H
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
Re: Steering Wheel Adjustment
Mine has just stopped (after 4 days of ownership on a 58 plate). It's going back to Saxtons to get resolved hopefully this week.. if I find out anything, I'll post it here.
On the phone, they said something about "syncing". I put the key in, jumped out, pushed the driver's seat all the way forward and it started working...... for about 10 mins, so there's obviously some kind of electrical issue (tried with both keys and neither works currently).
Cheers..
Ian
Post #439971 Mon Oct 20 2014 8:28am
vin297
Hi Ian,
Did you get yours resolved, if so do you know what it was?
Vin
Post #440368 Fri Oct 24 2014 6:59pm
Ian.H
Hi mate..
Not as yet, it's finally going back early next week (not had an easy ride in trying to get things resolved as yet).
Out of curiosity, has anything else stopped working for you? I've lost:
  • Steering wheel adjustment
  • Key recognition options (steering wheel / seat not going into "easy access" positions when key removed)
  • Memory seat positions not working
  • Fridge not working
  • Sunroof stopped working
  • Seat forward / backward adjustment works, but seems to be in "steps" (I have to keep moving the button to continue) rather than a single fluid movement.
  • Powerfold mirrors fold, but glass not adjustable
Not being a RR specialist, I suspect the lot maybe somewhat connected as everything seemed to stop at the same time.
Sorry I can't offer anything else at present mate, but as soon as I find out something (assuming they give me an answer), I'll let you know.
Cheers..
Ian
PS: I'm only down the road from you in the Ruislip area.. maybe it's something in the air!
Post #440371 Fri Oct 24 2014 7:14pm
vin297
everything else seems fine, I had the memory module replaced at LPR (you may have seen my previous posts) and im pretty sure its something to do with that as I cant find a fuse just for the steering wheel. I need to ideally find a good indie near us, any ideas? I am prepared to try out LPR again given James is back there but its just a bit a nightmare journey at the times I could go there.
Post #440467 Sun Oct 26 2014 5:50am
Ian.H
Well mine should be going back tomorrow to get looked at, but not holding my breath (that's a separate issue I'll address on here once I do finally get things resolved) so currently still at a loss as to what any of it could be. I've checked the fuses and none seem to be blown, so I "fear" that it's something deeper into the system.
As for places to go, I don't know of any other than Park Royal (it was HR Owen last time I was there), but do plan to start trying to find somewhere more local, or at least, an easier journey to get to.
Cheers..
Ian
Post #440949 Thu Oct 30 2014 3:53pm
Ian.H
Hi mate..
Just got my RRS back today. Turns out it was apparently a dodgy electronic switch somewhere in the memory seat that was causing the problem with all of my electrical things (including the steering wheel adjustment). No idea what was involved work-wise or price-wise in getting this fixed as it was done back at the dealership FoC for me, but apparently that's what it was.. and it's all working again now for me.
Cheers..
Ian
Post #442561 Fri Nov 14 2014 1:25pm
DorsetJag
Reviving old topic...
I also have no steering wheel adjustment but everything else works fine. Does anyone know how to find the fault?
Post #644821 Mon Oct 21 2024 5:35pm
DorsetJag
Correction. Although the memory function works the convenience feature doesn't. I think I need to check if it's been switched off in CCD
Post #644843 Tue Oct 22 2024 4:12pm
