Home > Faults & Fixes > Over heating from time to time |
johnunleashed Member Since: 13 Jul 2014 Location: Lancashire Posts: 59 |
Hi when does it do it , in traffic , on motor way , under heavy load ! 2007 SUPERCHARGED HST |
Fri Oct 17 2014 8:30am |
JasM Member Since: 02 Nov 2012 Location: Lanarkshire Posts: 1186 |
Could be a faulty thermostat. 2014 L405 SDV8 RR Autobiography
Fri Oct 17 2014 9:06am |
R8BHX Member Since: 11 Oct 2014 Location: Essex Posts: 8 |
I could be driving alone stop and restart the car and it will do it? I ordered a switch today land rover think it could be that? It's mad coz it over heats and with in seconds it back to normal but my old heart is pumping when it's doing it |
Fri Oct 17 2014 11:10am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4420 |
IIRC, a 55 plate is in the chassis range for the petrol models to have the Aux coolant pump to be wired the wrong way round.
Fri Oct 17 2014 6:05pm |
Would that cause a air lock as well? Mine was fine until I had something changed on the stearing a angle join or something like that? |
Fri Oct 17 2014 9:11pm |
did it just air lock the once ? Do you have to top up the water level ? 2007 SUPERCHARGED HST |
Sat Oct 18 2014 7:05am |
Not sure think I let some out last night? Removed pipes topped up put back together and back to normal
Sat Oct 18 2014 9:05am |
ok re check the coolant when the engine is cold ,and check it is on the cold mark on the header tank , don't over fill it .How long has it been over heating for ? 2007 SUPERCHARGED HST |
Sat Oct 18 2014 9:37am |
It's on and off been prob about 3 4 days doesn't happen all the time which is mad it will go up then drop when it does it? |
Sat Oct 18 2014 10:05am |
dont think it is the Auxillary Electric Water Pump as it puts a light on , and you get power loss 2007 SUPERCHARGED HST |
Sat Oct 18 2014 10:24am |
No warning lights what so ever come on? |
Sat Oct 18 2014 11:55am |
