Home > Faults & Fixes > Over heating from time to time
R8BHX
Hi got a question I need answering got a 55 sport petrol supercharger,
Every now and then I get the temp level going upto the red? After a few seconds it drops? I looked at water level and had a air lock removed but it still happens every now and then?
Any ideas could something be sticking? Stat or anything else possible
Thanks
Rob
Post #439651 Fri Oct 17 2014 7:05am
johnunleashed
2007 Range Rover Sport Supercharged HST Java Black
Hi when does it do it , in traffic , on motor way , under heavy load ! 2007 SUPERCHARGED HST
Post #439668 Fri Oct 17 2014 8:30am
JasM
Scotland 2012 Range Rover Sport SDV6 HSE Orkney Grey
Could be a faulty thermostat. 2014 L405 SDV8 RR Autobiography Cool
2012 RRS SDV6 HSE -Orkney Grey with A/B bodykit - Now Gone Sad
2007 RRS TDV6 HSE - Zermatt Silver - Gone
Post #439672 Fri Oct 17 2014 9:06am
R8BHX
I could be driving alone stop and restart the car and it will do it? I ordered a switch today land rover think it could be that? It's mad coz it over heats and with in seconds it back to normal but my old heart is pumping when it's doing it
Post #439683 Fri Oct 17 2014 11:10am
Disco_Mikey
IIRC, a 55 plate is in the chassis range for the petrol models to have the Aux coolant pump to be wired the wrong way round.
Quote:
LTB00041v2 concerns "Reduced Power With The Possibility Of Diagnostic Trouble Code
(DTC) P0096 and/or P2601 Stored".
4.2L V8 Supercharged Only VIN- range :5A901924-7A109767 are affected.
The cause is "the electrical harness supply and earth for the auxiliary coolant pump may be found to be cross connected in connector C3006, causing the Engine Control Module (ECM) to reduce power to prevent damage because the pump flow is low. The auxiliary coolant pump will be degraded because it has been running backwards".
Smile
Post #439724 Fri Oct 17 2014 6:05pm
R8BHX
Would that cause a air lock as well? Mine was fine until I had something changed on the stearing a angle join or something like that?
Post #439750 Fri Oct 17 2014 9:11pm
johnunleashed
did it just air lock the once ? Do you have to top up the water level ? 2007 SUPERCHARGED HST
Post #439764 Sat Oct 18 2014 7:05am
R8BHX
Not sure think I let some out last night? Removed pipes topped up put back together and back to normal
But was unsure if it should suck from top right and goes to a black roundish box maybe stat?
Post #439786 Sat Oct 18 2014 9:05am
johnunleashed
ok re check the coolant when the engine is cold ,and check it is on the cold mark on the header tank , don't over fill it .How long has it been over heating for ? 2007 SUPERCHARGED HST
Post #439789 Sat Oct 18 2014 9:37am
R8BHX
It's on and off been prob about 3 4 days doesn't happen all the time which is mad it will go up then drop when it does it?
Post #439793 Sat Oct 18 2014 10:05am
johnunleashed
dont think it is the Auxillary Electric Water Pump as it puts a light on , and you get power loss 2007 SUPERCHARGED HST
Post #439798 Sat Oct 18 2014 10:24am
R8BHX
No warning lights what so ever come on?
Post #439803 Sat Oct 18 2014 11:55am
