Home > General > No cruise control or horn
Hawkesport
The horn and cruise control have stopped working through my steering wheel, has anyone had this problem. I've checked horn fuse and that is fine, bit frustrating having no horn 😡 thanks in advance
Post #437838 Thu Sep 25 2014 6:55pm
Bodsy
Site Sponsor
Take the airbag off and check the wiring behind it. Otherwise it may well be the rotary coupler /clock spring.
If you need one, I have some never used ones £120 delivered Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #437863 Thu Sep 25 2014 10:43pm
Hawkesport
Ok cheers for that will check it out when I can. The volume and track change still work on other side of wheel, does this still make you think rotary coupler. Cheers
Post #437964 Sat Sep 27 2014 2:14pm
