The horn and cruise control have stopped working through my steering wheel, has anyone had this problem. I've checked horn fuse and that is fine, bit frustrating having no horn 😡 thanks in advance
Thu Sep 25 2014 6:55pm
Bodsy Site Sponsor
Take the airbag off and check the wiring behind it. Otherwise it may well be the rotary coupler /clock spring.
If you need one, I have some never used ones £120 delivered Bodsys Brake Bible Software Updates Contact me RRS Timed Heat/Remote kits - Contact me BAS Engine Re-maps/ EGR Blank EuIII and EuIV Clock On The Dash/ SNOTM /3Flash / BT Update /Service Reset/Error Codes read\ Gearbox Reset See it HERE
Thu Sep 25 2014 10:43pm
Hawkesport
Ok cheers for that will check it out when I can. The volume and track change still work on other side of wheel, does this still make you think rotary coupler. Cheers
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
