![]() | Home > General > Hawke Exhaust Tips |
hodjie Member Since: 13 Nov 2013 Location: United Kingdom Posts: 91 ![]() ![]() ![]() |
hi there ,ive got overfinch tips on and their welded on ,anything else and they ll get nicked straight away |
Cooler King Member Since: 13 Aug 2014 Location: Sunderland Posts: 3 ![]() ![]() ![]() |
Thanks...I though welding them on might have been a solution...think this is what i'll end up doing. |
B16JUS Member Since: 25 Jul 2014 Location: Essex Posts: 26 ![]() ![]() |
any pics ? |
andman Member Since: 08 Oct 2011 Location: la vella Posts: 1155 ![]() ![]() ![]() |
Can't beat a nice pair of tips .... |
Danny.H Member Since: 25 Aug 2014 Location: Brechin, Angus Posts: 91 ![]() ![]() ![]() |
I've recently put a set on mine, as well as the tip mounting bolts I've got them held on tight with the U brackets. I think most folks would think its part of the exhaust system anyway and not even consider trying to steal them, if they did they'd need to be carrying tools with them as mine are on that tight you'd never pull them off. |
designboy Member Since: 03 Feb 2014 Location: whitehead co antrim Posts: 338 ![]() ![]() ![]() |
I would use some sort of adhesive - them liquid metal ones that does not mind heat. But the above post makes sense, you should be okay with them on. Is it worth stealing something off a drug dealer styled car for £100? I love mine, but it does look like I'm a crook! |
