Home > General > Hawke Exhaust Tips
Cooler King
Hawke Exhaust Tips
Just bough a set of the Stainless Steel exhaust tips from Hawke...put them on and they look great...but took them off that same night which only took a minute or so to do...that's the problem, even though the car is parked on the drive they are so easy to take off. Any body got any tips how to fix them on so they are more secure!!!...don't fancy paying the £151 for somebody to come along and whip them off....which I'm sure will happen if they are only bolted on.
Post #434404 Thu Aug 28 2014 4:42pm
hodjie
United Kingdom 2011 Range Rover Sport Supercharged Autobiography Fuji White
hi there ,ive got overfinch tips on and their welded on ,anything else and they ll get nicked straight away Big Cry
Post #434459 Thu Aug 28 2014 8:44pm
Cooler King
Thanks...I though welding them on might have been a solution...think this is what i'll end up doing.
Post #434463 Thu Aug 28 2014 8:58pm
B16JUS
any pics ?
Post #434548 Fri Aug 29 2014 7:47pm
andman
Andorra 2011 Range Rover Sport 3.0 TDV6 HSE Fuji White
Can't beat a nice pair of tips .... Rolling with laughter 2014.5 SDV6 AB Dynamic ... Fuji /Santorini Pan roof and 22's
2013 Porsche Boxster S 3.4
2014 Audi A3 S line Quattro
Post #434730 Sun Aug 31 2014 6:04pm
Danny.H
Scotland 2007 Range Rover Sport TDV6 HSE Java Black
I've recently put a set on mine, as well as the tip mounting bolts I've got them held on tight with the U brackets. I think most folks would think its part of the exhaust system anyway and not even consider trying to steal them, if they did they'd need to be carrying tools with them as mine are on that tight you'd never pull them off. Smile
Post #434733 Sun Aug 31 2014 6:17pm
designboy
United Kingdom 2007 Range Rover Sport TDV8 HSE Lux Stornoway Grey
I would use some sort of adhesive - them liquid metal ones that does not mind heat. But the above post makes sense, you should be okay with them on. Is it worth stealing something off a drug dealer styled car for £100? I love mine, but it does look like I'm a crook!
Post #435447 Sat Sep 06 2014 4:29pm
