Home > Technical > TDV8 Engine help please
Embo
United Kingdom 2007 Range Rover Sport TDV8 HSE Santorini Black
Hi folks , ive had my rrs tdv8 for nearly 2 years with no problems what so ever . Last week I went to a vw car show in shrewsbury , there was stand there called ACE Carcare . I had my range rover re-mapped (black code) and the engine terracleaned , while the engine was being terracleaned I noticed loads of blue/grey smoke coming out of the back ! the salesman said this was normal ?? , when they had finished I parked the car until the morning when I started my journey home . 25 miles into the journey I heard a load `pop` and the car was smoking really bad from the exhausts .I got the car recovered to a local independent land rover garage and they have told me no2 piston has failed and I need a new engine Crying or Very sad the bill for this is going to be £10,500.00 Crying or Very sad Crying or Very sad I am trying to claim on black codes warranty but they are not returning my calls Mad
Can anybody recommend where I can get an engine , I have heard of a place in Scotland called engine engineering but I need a bit of feed back / advice from you guys on here Smile thanks
Post #427145 Sat Jun 14 2014 9:57am
adigorn
Are you positive about the diagnose
most of cases its only egr failure giving similar symptoms?
Post #427146 Sat Jun 14 2014 10:14am
muddywheels
Milk Float Man
Simple1 is the best person here to give advice on your problem - he's been through it already Sad
http://www.rrsport.co.uk/forum/topic31666.html?highlight=tdv8
Send him a pm if he doesn't see your post http://www.rrsport.co.uk/forum/member-simple1.html Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #427148 Sat Jun 14 2014 10:22am
Embo
the report said they removed injectors and did a cylinder compression test , found no2 injector wet with engine oil , all compression around 20 bar except number 2 at 9 bar .?? inspected top of pistons , suspect pistons failed. requires futher investigation which would mean remove engine strip and inspect pistons
Post #427149 Sat Jun 14 2014 10:53am
Disco_Mikey
Re: TDV8 Engine help please
This place has been discussed on D3: http://www.disco3.co.uk/forum/topic105707....ngineering
Best advice is to avoid
Post #427156 Sat Jun 14 2014 2:20pm
Terryrrs
Take a look at this topic
http://www.bmwland.co.uk/forums/viewtopic.php?t=104660
Terry
Post #427160 Sat Jun 14 2014 4:09pm
