![]() | Home > Technical > TDV8 Engine help please |
adigorn Member Since: 17 Mar 2010 Location: Birmingham Posts: 110 ![]() ![]() ![]() |
Are you positive about the diagnose
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
Simple1 is the best person here to give advice on your problem - he's been through it already |
Embo Member Since: 13 Nov 2012 Location: Newcastle/under/lyme Posts: 23 ![]() ![]() ![]() |
the report said they removed injectors and did a cylinder compression test , found no2 injector wet with engine oil , all compression around 20 bar except number 2 at 9 bar .?? inspected top of pistons , suspect pistons failed. requires futher investigation which would mean remove engine strip and inspect pistons |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4422 ![]() ![]() ![]() |
This place has been discussed on D3: http://www.disco3.co.uk/forum/topic105707....ngineering Best advice is to avoid |
Terryrrs Member Since: 25 Dec 2013 Location: Suffolk Posts: 158 ![]() ![]() |
Take a look at this topic
