Home > Technical > TDV8 Engine help please |
adigorn Member Since: 18 Mar 2010 Location: Birmingham Posts: 110 |
Are you positive about the diagnose
Sat Jun 14 2014 11:14am |
muddywheels Milk Float Man Member Since: 01 Jul 2010 Location: East Riding of Yorkshire Posts: 5636 |
Simple1 is the best person here to give advice on your problem - he's been through it already
Sat Jun 14 2014 11:22am |
Embo Member Since: 13 Nov 2012 Location: Newcastle/under/lyme Posts: 23 |
the report said they removed injectors and did a cylinder compression test , found no2 injector wet with engine oil , all compression around 20 bar except number 2 at 9 bar .?? inspected top of pistons , suspect pistons failed. requires futher investigation which would mean remove engine strip and inspect pistons |
Sat Jun 14 2014 11:53am |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4378 |
This place has been discussed on D3: http://www.disco3.co.uk/forum/topic105707....ngineering Best advice is to avoid |
Sat Jun 14 2014 3:20pm |
Terryrrs Member Since: 25 Dec 2013 Location: Suffolk Posts: 158 |
Take a look at this topic
Sat Jun 14 2014 5:09pm |
