Home > Maintenance & Modifications > Squeaking Noise from RRSport 2.7
dukeminster
My range rover has started squeaking loudly whilst idling and at speeds. Can anyone shed some light on this? With the bonnet up and engine on it sounds like it is coming from the belts at the front of the engine. Less than 4 weeks ago it had a cambelt and timing chains changed.
I've done a video so you can hear the kind of noise that is going on:
https://www.youtube.com/watch?v=Dt3tjGIVq-I Neutral
Thanks
Post #423307 Mon May 05 2014 9:55pm
RRSNorway
Norway 2006 Range Rover Sport TDV6 HSE Zermatt Silver
got the same prob. let us know what you find out;)
Post #423313 Mon May 05 2014 10:37pm
slim_sane
United Kingdom 2013 Range Rover Sport SDV6 HSE Santorini Black
I had the same on my old rrs, I changed all the pulley tensioners as it was bearing in one of them so I just decided to change them and the pulleys at the same time, cured the noise. Thumbs Up
Post #423316 Mon May 05 2014 10:44pm
dukeminster
Thanks for the reply slim, hopefully shouldn't be too costly to fix then!
Post #423341 Tue May 06 2014 9:49am
dukeminster
Soooo.....No such luck it would seem.
They changed the puller tensioner and the noise remained.
They advised me that the ACE Pump was what was causing the noise. One of the cables had split off the pump, and drained the hydrolic fluid, causing the pump to run unlubricated, and knackering the pump.
I've had a new ACE Pump, a new fan, new fluid, and a couple of other bits done.
All in it came to £1500. With only £120 labour. £800 of that was the ACE Pump.
Big Cry Sad
My advice to anyone seeing the red suspension light on the dash is don't drive it, and get it looked at immediately.
Post #424279 Wed May 14 2014 5:09pm
dukeminster
Unfortunately my problems continue!
It worked fine for a few days, then the warning light reappeared.
I took it back to the garage and they read the codes. Unfortunately they don't know what to do from here. Short of taking it to a Land Rover dealer neither do I!
The fault codes I am getting are apparently all related to drive height, and they are:
B0002 - Drivers Front Air Control
U0434 Invalid Data recieved from Dynamic Response Module
U0132 Lost Comms Ride Level Control Module
U0182 Lost Comms Front Light Control Module
U0182 Lost Comms Park Assist Control Module
P0578 Speed Con Multi Function trip Airbag (I believe this to be a seperate issue, passanger seat moved forward causing airbag light to trip)
Can anyone shed any light on this?
Post #424883 Wed May 21 2014 3:50pm
Disco_Mikey
Going on those fault codes, you will probably need it hooked upto an LR specific code reader, and read the faults in every module Thumbs Up
Post #424888 Wed May 21 2014 5:01pm
