Home > Maintenance & Modifications > Squeaking Noise from RRSport 2.7 |
dukeminster Member Since: 26 Apr 2013 Location: United Kingdom Posts: 29 |
My range rover has started squeaking loudly whilst idling and at speeds. Can anyone shed some light on this? With the bonnet up and engine on it sounds like it is coming from the belts at the front of the engine. Less than 4 weeks ago it had a cambelt and timing chains changed.
Mon May 05 2014 8:55pm |
RRSNorway Member Since: 08 Jan 2012 Location: norway Posts: 314 |
got the same prob. let us know what you find out;) |
Mon May 05 2014 9:37pm |
Thanks for the reply slim, hopefully shouldn't be too costly to fix then! |
Tue May 06 2014 8:49am |
Soooo.....No such luck it would seem.
Wed May 14 2014 4:09pm |
Unfortunately my problems continue!
Wed May 21 2014 2:50pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4413 |
Going on those fault codes, you will probably need it hooked upto an LR specific code reader, and read the faults in every module |
Wed May 21 2014 4:01pm |
