![]() | Home > General > Just had rrs at 160 mph |
Now IF you dropped your Sport out the rear end of a Hercules it may do it |
drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163 ![]() ![]() ![]() |
Actually the aerodynamic drag might be sufficient that, even in free-fall, it would reache a terminal/stead-state velocity closer to 140mph - depending on the altitude of the Herc and the air temperature at the time, angle of attack etc. etc. For a RRS without aerodynamic aids to reach 160mph is indeed pushing it. While the standard top gear may theoretically keep the engine within its maximum rev band you'd need to ensure that maximum power is output at maximum revs; which is rarely the case. |
DavidHirst Member Since: 07 Sep 2013 Location: york Posts: 93 ![]() ![]() ![]() |
Theres a Specsavers in Driffield Speedy, Think you need to make an appointment. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
If you just put it in a Herc and flew it around a bit you'd be doing more than 160mph and you'd be able to use it again afterwards! ![]() ![]() 2008 TDV8 - it was a labour of love and is much missed |
jochem00 Member Since: 16 Oct 2013 Location: Monaco Posts: 85 ![]() |
well, why do you guys believe it is physically impossible to reach 160 M/hour.
Two completely different vehicles. |
Just to muddy the waters...
I wonder if 160mph would be achievable on a rolling road in a RRS SC |
rigpig100 Member Since: 30 Jul 2013 Location: angloa until the 18th !! Posts: 263 ![]() ![]() |
160 mph ? not a hope in hell does any one know what the drag coefficient of the RR is ? |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Rigpig,
rickshaw Member Since: 03 Jul 2007 Location: West Yorkshire Posts: 195 ![]() ![]() ![]() |
Well MY RRS will do 161 mph so there!! And it was uphill !!! And it did 7.0 mpg!!!!
found this
Rigpig, thats for the new sport, the OP is talking about the RRS1 with the 6 speed gearbox. |
Too much time on my hands then, I shall adjourn to the pub !!! |
