Home > General > Leaking ace bar and brake pipe |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Did they remove the body to do the job? 2x TDV6. SE and HSE. Both returned to sender with issues👀
Tue Jan 28 2014 7:41am |
T18 Member Since: 27 Jan 2014 Location: Leeds Posts: 2 |
Not sure they said it was a 4 hour job, they have now reported back that the pipe are corroded, the check list that they gave me said every thing was fine, so they said it the pipe higher up |
Tue Jan 28 2014 8:50am |
Pipes sit above Arb and out of site behind a shield. Noticed on mine when body off that pipes were rusty as was floor pan. Not good news as LR will take body off to do pipes, Indi will do it with body on. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Tue Jan 28 2014 9:02am |
