Home > General > Leaking ace bar and brake pipe
T18
I had a leak on my rrs, taken it to land rover and they have replaced the rear ace bar. After collecting the car the bake light on the dash came on. Had new pads a couple of months ago so no it wasn't them so checked brake fluid empty, filled the fluid and noticed a leak at the back near the first leak.
Do u have to disconnect the brakes to replace the ace bar? Or could the pipe of been damaged while replacing the ace bar?
Post #411319 Mon Jan 27 2014 1:34pm
simple1
Did they remove the body to do the job? 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #411417 Tue Jan 28 2014 7:41am
T18
Not sure they said it was a 4 hour job, they have now reported back that the pipe are corroded, the check list that they gave me said every thing was fine, so they said it the pipe higher up
Post #411424 Tue Jan 28 2014 8:50am
simple1
Pipes sit above Arb and out of site behind a shield. Noticed on mine when body off that pipes were rusty as was floor pan. Not good news as LR will take body off to do pipes, Indi will do it with body on. Big Cry 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #411428 Tue Jan 28 2014 9:02am
