Home > Faults & Fixes > Engine problem |
ELD70 Member Since: 19 Jan 2009 Location: UK Posts: 163 |
Flat battery. |
Sat Jan 18 2014 11:26am |
Tim Hoang Member Since: 29 Jan 2008 Location: London Posts: 77 |
May be the air comp. pump. on the way out. 2005 RRS TDV6 HSE Java Black
Sat Jan 18 2014 12:16pm |
Perhaps the OP is referring to the TDV6's tendency to make a tapping noise on start-up? It's the hydraulic valve lifters tapping until the oil pressure builds up. It has been reported that if it is really bad then changing the oil filter for a genuine Land Rover item sometimes helps the oil pressure to build a bit more quickly. An oil change might help too if the present oil is old and thin. Nevertheless many TDV6 owners say it's a characteristic of the engine. 2008 MY Java Black TDV8 HSE
Sat Jan 18 2014 1:18pm |
