Home > Faults & Fixes > Engine problem
oktaykorkurt@hotmail.co.uk
United Kingdom 2007 Range Rover Sport TDV6 S Santorini Black
Engine problem
Big Cry Big Cry Help please, rrsport 07 plate making engine click noise at start for about 5 seconds,just bought it two months ago bit worried if its some thing serious.
Post #409976 Fri Jan 17 2014 9:34pm
ELD70
Flat battery.
Post #410018 Sat Jan 18 2014 11:26am
Tim Hoang
May be the air comp. pump. on the way out. 2005 RRS TDV6 HSE Java Black
2005 997 C2
Post #410025 Sat Jan 18 2014 12:16pm
Paddi
Perhaps the OP is referring to the TDV6's tendency to make a tapping noise on start-up? It's the hydraulic valve lifters tapping until the oil pressure builds up. It has been reported that if it is really bad then changing the oil filter for a genuine Land Rover item sometimes helps the oil pressure to build a bit more quickly. An oil change might help too if the present oil is old and thin. Nevertheless many TDV6 owners say it's a characteristic of the engine. 2008 MY Java Black TDV8 HSE
Post #410031 Sat Jan 18 2014 1:18pm
