![]() | Home > General > Rear number plate |
When your wife goes out, steal her hair dryer and heat the plate up starting at one corner and gently pull the plate away from the tailgate as it melts the glue and keep heating the rest of the plate as it comes away. Some use fishing wire or cotton and feed that behind the plate at the same time as heating the plate up and just the wire like a saw to cut through the sticky pad. Or if you have a heat gun use that but DON'T melt your plate |
AndyLandy Member Since: 26 Nov 2013 Location: Bassingbourn Posts: 39 ![]() ![]() ![]() |
Hi,
Talk nicely to your neighbour and ask them if they have one you can borrow. |
No, I will buy one, tell her its an early birthday pressie |
Tesco, £8, that will do |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 ![]() ![]() ![]() |
Grab one corner and yank (plate not the Mrs), pliers if needed - the tape will give, the plate may not survive, getting the old tape off is a |
Agree with the hairdryer - it's a good start.
simonj007 Member Since: 11 Sep 2013 Location: Buckinghamshire Posts: 148 ![]() ![]() ![]() |
Could you theoretically stick a new plate over the old one?
Friend of mine has a bodyshop and the only way they have found to get the tape off is with some polishing wheel - decent plate tape is a |
We used plastic spatular then a flapper wheel. Wurst make a product that removes glue/residue of tape without effort. 2x TDV6. SE and HSE. Both returned to sender with issues👀
@ MAW - I soak some kitchen towel/tissue in AS Tardis and then press it onto the glue/residue. Leave it for 15 mins and it makes it a doddle to remove. You just need to make sure it's got enough contact time |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
We use screws through pre-drilled holes. |
Will try that next time and save my thumbnails ![]() |
