Home > General > Rear number plate
AndyLandy
England 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Rear number plate
Hi all,
Does anyone know the best way to remove a stuck on, and I mean stuck on Evil or Very Mad rear number plate?
As I dont want to damage the paint Embarassed
Thanks in advance,
Andy Rules are for the obediance of fools and the guidence of wise men
Post #407861 Thu Jan 02 2014 6:44pm
When your wife goes out, steal her hair dryer and heat the plate up starting at one corner and gently pull the plate away from the tailgate as it melts the glue and keep heating the rest of the plate as it comes away. Some use fishing wire or cotton and feed that behind the plate at the same time as heating the plate up and just the wire like a saw to cut through the sticky pad. Or if you have a heat gun use that but DON'T melt your plate Big Cry
Post #407862 Thu Jan 02 2014 7:00pm
AndyLandy
Thanks for that,
Gawd knows what it is stuck on with as it is flush to the tailgate.
Will have to buy a hair dryer as the Mrs does not own one, bit of a Censored as I dont have any hair Rolling with laughter
Thumbs Up Rules are for the obediance of fools and the guidence of wise men
Post #407863 Thu Jan 02 2014 7:06pm
Talk nicely to your neighbour and ask them if they have one you can borrow. Wink
Post #407864 Thu Jan 02 2014 7:08pm
AndyLandy
No, I will buy one, tell her its an early birthday pressie Laughing Rules are for the obediance of fools and the guidence of wise men
Post #407865 Thu Jan 02 2014 7:11pm
AndyLandy
Tesco, £8, that will do Very Happy Rules are for the obediance of fools and the guidence of wise men
Post #407867 Thu Jan 02 2014 7:14pm
MAW
Grab one corner and yank (plate not the Mrs), pliers if needed - the tape will give, the plate may not survive, getting the old tape off is a Censored
Post #407869 Thu Jan 02 2014 7:38pm
Agree with the hairdryer - it's a good start.
Also worth applying some type of glue remover to soften up the tape that's holding it on. Look on eBay for Autosmart Tardis.
The final thing you need is some fishing line. Once you've heated the plate and applied the glue remover, then gentle 'saw' with the fishing line to separate the plate from the car. Then use the remaining glue remover to take off any sticky stuff left on the car Smile
I'd avoid, just taking it off personally as the plate could shatter and damage the car. ON THE WAY: BMW F21 M140i
Post #407904 Fri Jan 03 2014 8:58am
simonj007
England 2007 Range Rover Sport Supercharged Zermatt Silver
Could you theoretically stick a new plate over the old one?
I only ask as I've private plates coming Wink
S
Post #407910 Fri Jan 03 2014 9:49am
MAW
Friend of mine has a bodyshop and the only way they have found to get the tape off is with some polishing wheel - decent plate tape is a Censored , I have never found anything to dissolve the adhesive.
Post #407912 Fri Jan 03 2014 9:59am
simple1
We used plastic spatular then a flapper wheel. Wurst make a product that removes glue/residue of tape without effort. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Post #407914 Fri Jan 03 2014 10:17am
@ MAW - I soak some kitchen towel/tissue in AS Tardis and then press it onto the glue/residue. Leave it for 15 mins and it makes it a doddle to remove. You just need to make sure it's got enough contact time Thumbs Up ON THE WAY: BMW F21 M140i
Post #407919 Fri Jan 03 2014 11:17am
BKHK
We use screws through pre-drilled holes. Laughing Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #407920 Fri Jan 03 2014 11:22am
Laughing BKHK......but screws and holes is sooooo last year.
I do prefer the clean look of stuck on plates. I've been looking into getting some super strong Velcro and will try that when I finally get around to sticking my personal plate on my BM. ON THE WAY: BMW F21 M140i
Post #407922 Fri Jan 03 2014 11:25am
MAW
Will try that next time and save my thumbnails Laughing
Post #407926 Fri Jan 03 2014 11:43am
