Home > Wheels & Tyres > Wheel spacers |
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 |
What size of wheel are you using, certain wheels will not fit |
Sun Dec 15 2013 8:52pm |
stebenny Member Since: 15 Dec 2013 Location: leyland, Lancashie Posts: 120 |
Both sets of wheels are 19" the new ones will fit on the hub but will touch the brembos thats why i thought the wheel spacers would solve the problem, Thanks |
Sun Dec 15 2013 9:09pm |
What width though, I think it is 9x19's that fit - 8's do not
Sun Dec 15 2013 9:21pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4416 |
DO you have a picture of the wheels, to help us identify them?
Sun Dec 15 2013 9:25pm |
The wheels say 9R / 19 and are genuine land rover if that helps.. |
Sun Dec 15 2013 9:30pm |
Not really |
Sun Dec 15 2013 9:55pm |
Hi i might not be explaining myself very well..The wheels will fit over the brakes its the spokes that would be touching, Thats why i got the wheel spacers to bring the wheel out its the wheel spacers that wont fit, Thanks |
Sun Dec 15 2013 10:55pm |
There is not much clearance as standard between them, have you actually tried the wheels......iirc it's a matter of mm |
Sun Dec 15 2013 10:58pm |
I did and your right it was a matter of mm,s i just thought they would touch if i went over a bump our something, Lol I take it that they will be ok then, |
Sun Dec 15 2013 11:05pm |
Once the wheels are bolted up tight onto the hubs, if they do not foul the caliper then, they will be fine
Mon Dec 16 2013 6:35am |
Hi this is were my problem first started i bought the spacers 25mm to be sure but the spacers wont fit the wheel hub the bolts line up but the hole in the center is not big enough, The company who i bought them from say they have sold loads for a RRS 07 and have never had any problems.. |
Mon Dec 16 2013 7:32am |
Marsie Member Since: 20 Jul 2011 Location: sheffield Posts: 376 |
I fitted some 20"wheels off a RRsport to my HST and they were EXTREMELY close to the calipers Put it this way, if i had given the calipers another coat of paint they would have touched
Mon Dec 16 2013 9:49am |
So its not a wheel issue, its a spacer issue... All RRS hubs are the same, if they don't fit yours, they won't fit any RRS |
Mon Dec 16 2013 10:09am |
OP -
Mon Dec 16 2013 2:15pm |
