![]() | Home > Wheels & Tyres > Wheel spacers |
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 ![]() ![]() ![]() |
What size of wheel are you using, certain wheels will not fit |
stebenny Member Since: 15 Dec 2013 Location: leyland, Lancashie Posts: 120 ![]() ![]() ![]() |
Both sets of wheels are 19" the new ones will fit on the hub but will touch the brembos thats why i thought the wheel spacers would solve the problem, Thanks |
What width though, I think it is 9x19's that fit - 8's do not
DO you have a picture of the wheels, to help us identify them?
The wheels say 9R / 19 and are genuine land rover if that helps.. |
Not really |
Hi i might not be explaining myself very well..The wheels will fit over the brakes its the spokes that would be touching, Thats why i got the wheel spacers to bring the wheel out its the wheel spacers that wont fit, Thanks |
There is not much clearance as standard between them, have you actually tried the wheels......iirc it's a matter of mm |
I did and your right it was a matter of mm,s i just thought they would touch if i went over a bump our something, Lol I take it that they will be ok then, |
Once the wheels are bolted up tight onto the hubs, if they do not foul the caliper then, they will be fine |
Hi this is were my problem first started i bought the spacers 25mm to be sure but the spacers wont fit the wheel hub the bolts line up but the hole in the center is not big enough, The company who i bought them from say they have sold loads for a RRS 07 and have never had any problems.. |
Marsie Member Since: 20 Jul 2011 Location: sheffield Posts: 376 ![]() ![]() ![]() |
I fitted some 20"wheels off a RRsport to my HST and they were EXTREMELY close to the calipers |
So its not a wheel issue, its a spacer issue... All RRS hubs are the same, if they don't fit yours, they won't fit any RRS |
OP -
