Home > Wheels & Tyres > Wheel spacers
stebenny
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Wheel spacers
Hi, I am new to the forum so not sure what to do yet, I have a RRS 2007 with Brembos on the front i bought some wheels from e-bay but they will touch the brakes if fitted i bought some spacers but they would not fit over the hub i returned to the company as we thought they had sent the wrong size they sent a new set but still did not fit the company said they had never had problems with them before, As anyone any ideas whey they would not fit, Thanks Steve
Post #406286 Sun Dec 15 2013 8:49pm
chris mc
Scotland 2011 Range Rover Sport TDV8 Autobiography Stornoway Grey
What size of wheel are you using, certain wheels will not fit
Post #406288 Sun Dec 15 2013 8:52pm
stebenny
Both sets of wheels are 19" the new ones will fit on the hub but will touch the brembos thats why i thought the wheel spacers would solve the problem, Thanks
Post #406290 Sun Dec 15 2013 9:09pm
chris mc
What width though, I think it is 9x19's that fit - 8's do not
I may be wrong though
Post #406295 Sun Dec 15 2013 9:21pm
Disco_Mikey
DO you have a picture of the wheels, to help us identify them?
Most (if not all) FFRR wheels from 02-05MY will not fit D3/RRS...
I have 8x19 wheels (Standard D3 HSE) which clear my Brembo's just fine Thumbs Up
Post #406296 Sun Dec 15 2013 9:25pm
stebenny
The wheels say 9R / 19 and are genuine land rover if that helps..
Post #406297 Sun Dec 15 2013 9:30pm
Disco_Mikey
Not really Whistle
Post #406299 Sun Dec 15 2013 9:55pm
stebenny
Hi i might not be explaining myself very well..The wheels will fit over the brakes its the spokes that would be touching, Thats why i got the wheel spacers to bring the wheel out its the wheel spacers that wont fit, Thanks
Post #406306 Sun Dec 15 2013 10:55pm
chris mc
There is not much clearance as standard between them, have you actually tried the wheels......iirc it's a matter of mm
Post #406307 Sun Dec 15 2013 10:58pm
stebenny
I did and your right it was a matter of mm,s i just thought they would touch if i went over a bump our something, Lol I take it that they will be ok then,
Post #406309 Sun Dec 15 2013 11:05pm
Disco_Mikey
Once the wheels are bolted up tight onto the hubs, if they do not foul the caliper then, they will be fine Thumbs Up
If they do rub when tight, then you need spacers.
I know my D3 wheels are bloody close to the calipers Shocked
Post #406313 Mon Dec 16 2013 6:35am
stebenny
Hi this is were my problem first started i bought the spacers 25mm to be sure but the spacers wont fit the wheel hub the bolts line up but the hole in the center is not big enough, The company who i bought them from say they have sold loads for a RRS 07 and have never had any problems..
Post #406315 Mon Dec 16 2013 7:32am
Marsie
United Kingdom 2008 Range Rover Sport TDV8 HST Stornoway Grey
I fitted some 20"wheels off a RRsport to my HST and they were EXTREMELY close to the calipers Shocked Put it this way, if i had given the calipers another coat of paint they would have touched Big Cry
Decided to refit the originals Thumbs Up
Paul
 Current fleet
2011 Discovery 3.0 sdv6 XS
2008 Range rover sport HST tdv8*gone*
2000 Porsche 911 Carrera 2 convertible
1996 TVR Chimaera*gone*
2004 Vauxhall combo van*dead* Sad
2003 ford ranger double cab
Post #406332 Mon Dec 16 2013 9:49am
Disco_Mikey
So its not a wheel issue, its a spacer issue...
All RRS hubs are the same, if they don't fit yours, they won't fit any RRS
Post #406334 Mon Dec 16 2013 10:09am
drdelrrs
OP -
Some where on the back of the wheel you should find the LR part number which will also state the OFF SET which I think for the RRS is 53.
Did the wheels come from a Sport/ - I see from your photo that you have a 275/45 tyre I thought (but might be wrong) the LR recommended 20" Sport tyres were all 40 section.
Post #406349 Mon Dec 16 2013 2:15pm
