Home > Faults & Fixes > Multiple Failures
jetbags
Multiple Failures
Hi All,
Some words of advice/wisdom required as have never seen these before....
Firstly, over the last couple of weeks have been getting HDC fault warning every time the car is started, then lately, this is now accompanied by a Transmission fault warning.
Today, after finding that i now have a puncture on one of the Scorpions, I tried raising and lowering the suspension a few times to see if this made any difference to the errors showing...... only to have a new error show up stating " Warning" suspension raising slowly.
This was something of an understatement, after selecting raised suspension the rear shoots up making the car look like some weird hot rod while the front raised up at a rate of 1mm every 2mins.
So, after 2 years of totally worry free motoring and a car that has exceeded every expectation, i now have multiple errors and faults to deal with.
Do you guys have any advice on the above or things to look for before its sent of to the garage for the inevitable huge invoice.?????
Regards 2005 Rang Rover Supercharged
Loving every minute !
Post #405336 Sun Dec 08 2013 5:15pm
G4LAND
Spain
See battery; HDC failure (and many others) when start, is frequently a battery issue. May be, you have to change just for a new battery. Thumbs Up Yuri
(ARS) XE1UN
13 RANGE ROVER SPORT HSE SDV6
Orkney Grey/Black
(Spain)
07 RANGE ROVER SPORT HSE TDV8
JavaBlack/Black
(SOLD)
05 DISCOVERY 3 G4 V8
(Spain)
02 DEFENDER 90 BLACK LE TD5
(SOLD)
13 FREELANDER 2 (LR2) HSE Lux SI4
Havana/Black
(Mexico)
Post #405339 Sun Dec 08 2013 5:43pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
The HDC fault was on mine when I had my recent battery issues. Didn't try to lower or raise the suspension so can't comment on that bit. My bet would be a new battery will fix everything.
Post #405345 Sun Dec 08 2013 6:13pm
Also, check that the brake bulbs are ok. A blown brake bulb has been known to throw up a HDC fault as the system will activate the brake lights when in use.
Other than that, check the battery before and after engine start. Ensure the alternator is working well.
The slow suspension rise at the front is likely to be the compressor feeling weak. A new compressor might be required. Alternatively it could be the valve block next to the compressor. 2012 SDV6 - it's missing a couple of cylinders
Post #405359 Sun Dec 08 2013 7:46pm
