Home > Faults & Fixes > Multiple Failures |
G4LAND Member Since: 16 Jan 2007 Location: VIGO Posts: 154 |
See battery; HDC failure (and many others) when start, is frequently a battery issue. May be, you have to change just for a new battery. Yuri
Sun Dec 08 2013 5:43pm |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 |
The HDC fault was on mine when I had my recent battery issues. Didn't try to lower or raise the suspension so can't comment on that bit. My bet would be a new battery will fix everything. |
Sun Dec 08 2013 6:13pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8982 |
Also, check that the brake bulbs are ok. A blown brake bulb has been known to throw up a HDC fault as the system will activate the brake lights when in use.
Sun Dec 08 2013 7:46pm |
