![]() | Home > Faults & Fixes > Multiple Failures |
G4LAND Member Since: 16 Jan 2007 Location: VIGO Posts: 154 ![]() ![]() |
See battery; HDC failure (and many others) when start, is frequently a battery issue. May be, you have to change just for a new battery. |
Bladeboy Member Since: 17 Sep 2013 Location: Benson Posts: 522 ![]() ![]() ![]() |
The HDC fault was on mine when I had my recent battery issues. Didn't try to lower or raise the suspension so can't comment on that bit. My bet would be a new battery will fix everything. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9051 ![]() ![]() ![]() |
Also, check that the brake bulbs are ok. A blown brake bulb has been known to throw up a HDC fault as the system will activate the brake lights when in use.
