Home > In Car Electronics > iPhone music streaming
Mrturner
2007 Range Rover Sport TDV6 HSE Stornoway Grey
Hi all,
What options are there to connect an iphone to a 2007 RRS? We gave been using the aux but as it's behind the central console it makes it a pain in the arse! If it's left plugged in it gets trampled or trapped when not is use, or you have to stop and pull over to plug in!
Is there a kit to replace the Nokia kit? Or a kit to replace the 6-disc changer connection?
Cheers,
Leigh 07 TDV6 HSE in Stornoway Grey, 20" alloys |08 XF SV8 on order.
Post #401901 Wed Nov 13 2013 8:58am
karan538
2008 Range Rover Sport TDV6 HSE Santorini Black
I use this:
http://www.amazon.co.uk/August-MR220B-Blue...h+receiver
its a Bluetooth receiver, leave it plugged into the aux and power in the mid console for unlimited bluetooth connectivity.
It recieves the bluetooth signal from your phone wirelessly and plays it through the aux port.
Crystal clear music Thumbs Up
Post #402015 Thu Nov 14 2013 2:32am
Mrturner
Has to be worth a punt at that price! Does your phone still work with the handsfree on the car? 07 TDV6 HSE in Stornoway Grey, 20" alloys |08 XF SV8 on order.
Post #402017 Thu Nov 14 2013 6:50am
sparky8181
As the phone can only be connected to one BT device at a time then your phone calls would be directed through this unit and not the cars BT, not an ideal situation as I would imagine the quality of the phone call would be no where near as good.
Post #402023 Thu Nov 14 2013 8:56am
Mrturner
Ah yes, multi-Bluetooth isn't gonna happen. Cd changer or aux seems the best option then, but can't find a cd changer lead! 07 TDV6 HSE in Stornoway Grey, 20" alloys |08 XF SV8 on order.
Post #402027 Thu Nov 14 2013 9:29am
MBaker
United Kingdom 2006 Range Rover Sport TDV6 HSE Bonatti Grey
Definitely going to give this a try for that price.
Mike.
Post #402880 Wed Nov 20 2013 3:11am
MBaker
Received my August MR220B receiver yesterday.
Very pleased indeed!! Works great and really clear!
Thanks for the link Karan538. Very Happy Thumbs Up
Mike.
Post #403392 Sat Nov 23 2013 8:08pm
AndyLandy
England 2008 Range Rover Sport TDV6 HSE Stornoway Grey
Hi all,
I will back this up, just brought one of the August receivers and plugged it in, fired up the bluetoof on Samsung phone S4 thingy and, Planet Rock booming through the speakers Cool Very Happy Rules are for the obediance of fools and the guidence of wise men
Post #408574 Tue Jan 07 2014 6:27pm
Brianx5
Scotland 2013 Range Rover Sport 3.0 TDV6 HSE Firenze Red
I will also give this the thumbs up ordered, delivered and 10 minutes to set up also fits into cubby hole below arm rest, remember to order USB charger, works with Samsung 3 Thumbs Up
Post #409135 Sat Jan 11 2014 5:10pm
Dannutt
England 2007 Range Rover Sport TDV8 HSE Buckingham Blue
Yeah I ordered one of these, paired it, plugged it into the car and went for a drive.
Worked perfectly Smile Until I parked up and left the car until the next day. Then my phone wouldn't connect to it, even if I then switched it off and back on.... So disappointed I ordered another one from a different supplier whilst I sent the first back. Same thing Sad
Do you folks all switch the August unit off when you leave the car or are you able to just leave it plugged into the car and switched on and connect?
Post #413827 Thu Feb 13 2014 12:05pm
Michael calvert
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Lux Nara Bronze
not iphone related
but my samsung galaxy note 3 can multi connect using bluetooth for instance the handsfree kit in the ar (both in the rrs, and the a5) whilst maintaining its pairing the compatible galaxy gear watch, 2010 RRS HSE 3.0 tdv6 2010MY
2012 Audi a5 2.0 tdi s-line
2005 Discovery 3 tdv6
2009 audi a4 2.0tdi saloon
2007 Audi a3 1.9tdi sportback
2004 Navara Double Cab
1996 Shogun 3.0 v6
1984 Landrover 90 2.5d
Post #413840 Thu Feb 13 2014 1:04pm
Brianx5
Hi I found out that you have to switch the unit off with the on/off switch at the side to reboot bluetooth before using
Post #413845 Thu Feb 13 2014 1:37pm
Dannutt
Michael calvert wrote:
not iphone related
So you have to take it out of the cubbie hole which it fits perfectly, switch it off and back on and put it back?
Thats dissapointing
Post #413848 Thu Feb 13 2014 1:59pm
Michael calvert
Thats dissapointing
not me> 2010 RRS HSE 3.0 tdv6 2010MY
1996 Shogun 3.0 v6
Post #413859 Thu Feb 13 2014 3:03pm
Dannutt
Wanna swap?
Post #413875 Thu Feb 13 2014 5:05pm
