Home > Technical > Heater Blower problem, resistor?
Mutley7074
Scotland 2006 Range Rover Sport Supercharged Java Black
Hi All,
new here to this forum so as a nice hello I hope someone can't shed some light on my little problem.
Basically, the heater blower has packed in, and doing a little bit of research it seams like the blower ( or final stage) resistor seems to be a common fault. I have bought the new resistor and hunted high and low for a guide on how to fit it. Everything I seem to find sounds and looks very straight forward, but i'm Censored if I can find it on my car (2006 4.2 S/C)
I think all the Youtube stuff is on a range rover, but not the RRS.
Any help would be much appreciated before I go and spend hundreds trying to fix this problem.
Jim
Post #399691 Thu Oct 24 2013 4:48pm
Martin
Site Administrator & Owner
I don't think it is a common fault, it is on the L322 Range Rover but not the RRS Confused
Assuming you have bought a blower motor control module (there is no "resistor" on the RRS) then it is located near the fan blower motor, behind the lower glove box. Like this site? Buy some RRSPORT goodies to show your support!
Post #399694 Thu Oct 24 2013 5:03pm
Mutley7074
I guess that'll explain why all the stuff I found was on the L322.
One day the blower was working fine then it just made a bit if a weird noise, there was s bit of a vibration for a few minutes then it just packed in. Could it be the blower motor that's gone? 2006 4.2.S/C RRS Java Black
1991 3.0 Honda NSX Sebring Silver
Post #399695 Thu Oct 24 2013 5:09pm
Martin
It might be the motor, have you checked the fuse? Fuse FL12 (not F12) in the engine compartment fuse box Like this site? Buy some RRSPORT goodies to show your support!
Post #399696 Thu Oct 24 2013 5:15pm
Mutley7074
Ill have a look at the fuses, but what makes me think that it is the motor, before it packed it, it got a noticeably louder and I could feel a vibration through the steering wheel, then it just stopped! 2006 4.2.S/C RRS Java Black
Post #399705 Thu Oct 24 2013 7:01pm
Disco_Mikey
The resistor is in the passenger side footwell, you need to take off the trim on the underside of the dash to access it
It sits in one of the air duct pipes, help in with 2x Philips head screws Thumbs Up
Post #399717 Thu Oct 24 2013 7:50pm
Paddi
The oracle has spoken Bow down Bow down
But..... Off Topic .... Do you by any chance own a small racing yacht of the Hunter 707 class called Mutley? 2008 MY Java Black TDV8 HSE
Post #399731 Thu Oct 24 2013 8:51pm
