![]() | Home > Technical > Heater Blower problem, resistor? |
Martin Site Administrator & Owner Member Since: 26 May 2005 Location: Hook Norton Posts: 3662 ![]() ![]() |
I don't think it is a common fault, it is on the L322 Range Rover but not the RRS |
Mutley7074 Member Since: 24 Oct 2013 Location: Lossiemouth Posts: 3 ![]() ![]() ![]() |
I guess that'll explain why all the stuff I found was on the L322.
It might be the motor, have you checked the fuse? Fuse FL12 (not F12) in the engine compartment fuse box Like this site? Buy some RRSPORT goodies to show your support! |
Ill have a look at the fuses, but what makes me think that it is the motor, before it packed it, it got a noticeably louder and I could feel a vibration through the steering wheel, then it just stopped! 2006 4.2.S/C RRS Java Black
The resistor is in the passenger side footwell, you need to take off the trim on the underside of the dash to access it
The oracle has spoken |
