Home > Faults & Fixes > Engine
jonesy_boys
United Kingdom 2006 Range Rover Sport TDV6 HSE Firenze Red
Engine
Hi guys, i have a range rover sport HSE 2006. THE PROBLEM IS THAT IT WONT START. PUT KEY IN IGNITION AND TURNS OVER BUT DOSENT START. ITS GOT FAULTS COMING UP ON SCREEN (HDC SYSTEM FAULT NOT AVAIBLE, TRANSMISSION FAULT, SUSPENSION FAULT, HAND BRAKE FAULT). IT ALSO HAS A SLIGHT KNOCK AND A LOT OF WHITE SMOKE COMING OUT THE EXHAUST? ANY HELP PLEASE!!
I THINK IT MIGHT BE INJECTORS OR EGR VAVLE?
PLEASE HELP!
Post #398942 Fri Oct 18 2013 6:49pm
BKHK
What engine, diesel or petrol? I can't tell from your post and models and HSE doesn't mean much here. The knock would worry me a lot but knocks are not always perceived the same by all ears, a knock to you may not be a knock. I suspect its more serious than an EGR valve? Gone - 2008 Stornoway Grey RRS 2.7 TDV6
Post #398991 Sat Oct 19 2013 3:19am
jonesy_boys
its a diesel 2.7 v8. it turns over but dosent start. i can get it started using easy start, but when its running theres alot of white smoke and a slight knock which comes and goes? it like its trying to clear?? still with all the faults coming up on the screen? many thanks.
Post #399009 Sat Oct 19 2013 9:31am
chRRS
2009 Range Rover Sport TDV6 HSE Stornoway Grey
2.7 V8? You mean V6 right?
Post #399012 Sat Oct 19 2013 10:00am
Disco_Mikey
Sounds very fuel system related, either an injector or fuel pumo, or potentially a damaged piston.
Hard to remotely diagnose faults like this. Are there any fault codes stored?
Post #399014 Sat Oct 19 2013 10:24am
jonesy_boys
yess, sorry its a v6. my heads all over the place. just want my sport running. many thanks.
Post #399019 Sat Oct 19 2013 11:01am
jonesy_boys
Hi guys, I changed the injectors after and turned it over and it eventually started. I took it out for a drive and it seems to be running ok. The only problem is it takes ages to start. Turns over for at least 20 seconds and it starts. The other problem is I plugged it in and it comes up over fuelling? Do I need it remapping again? Thanks for your help.
Post #401135 Tue Nov 05 2013 8:24am
Marsie
Have you taken a sample of the fuel? Had a similar fault on a car of mine (not a LR) a few years ago and it was all down to some dodgy fuel Rolling Eyes
Paul Current fleet
2011 Discovery 3.0 sdv6 XS
2008 Range rover sport HST tdv8*gone*
2000 Porsche 911 Carrera 2 convertible
1996 TVR Chimaera*gone*
2004 Vauxhall combo van*dead* Sad
2003 ford ranger double cab
Post #401179 Tue Nov 05 2013 8:17pm
jonesy_boys
Iv been running about in it and put well over £100 of diesel in it. So it should of cleared by now? That's what I was thinking see. :/. Many thanks.
Post #401216 Wed Nov 06 2013 10:24am
RRS Daz
If there was water in the diesel would that come out with use or would it need draining?
I known when I drowned my enduro bike in water and it gets in the carb it needs draining out.
Post #401221 Wed Nov 06 2013 11:05am
jonesy_boys
hi guys, sorry to change the subject. where are the glow plugs located on a range rover sport 2.7 td6? many thanks.
Post #403174 Fri Nov 22 2013 9:02am
Paddi
Does this help? Apparently they are barstewards to get out without breaking. Big Cry
 2008 MY Java Black TDV8 HSE
Post #403237 Fri Nov 22 2013 5:01pm
