![]() | Home > Faults & Fixes > Engine |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
What engine, diesel or petrol? I can't tell from your post and models and HSE doesn't mean much here. The knock would worry me a lot but knocks are not always perceived the same by all ears, a knock to you may not be a knock. I suspect its more serious than an EGR valve? Gone - 2008 Stornoway Grey RRS 2.7 TDV6
jonesy_boys Member Since: 18 Oct 2013 Location: cardiff Posts: 45 ![]() ![]() ![]() |
its a diesel 2.7 v8. it turns over but dosent start. i can get it started using easy start, but when its running theres alot of white smoke and a slight knock which comes and goes? it like its trying to clear?? still with all the faults coming up on the screen? many thanks. |
chRRS Member Since: 26 Jul 2013 Location: sheffield Posts: 19 ![]() ![]() |
2.7 V8? You mean V6 right? |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4451 ![]() ![]() ![]() |
Sounds very fuel system related, either an injector or fuel pumo, or potentially a damaged piston.
yess, sorry its a v6. my heads all over the place. just want my sport running. many thanks. |
Hi guys, I changed the injectors after and turned it over and it eventually started. I took it out for a drive and it seems to be running ok. The only problem is it takes ages to start. Turns over for at least 20 seconds and it starts. The other problem is I plugged it in and it comes up over fuelling? Do I need it remapping again? Thanks for your help. |
Marsie Member Since: 20 Jul 2011 Location: sheffield Posts: 376 ![]() ![]() ![]() |
Have you taken a sample of the fuel? Had a similar fault on a car of mine (not a LR) a few years ago and it was all down to some dodgy fuel |
Iv been running about in it and put well over £100 of diesel in it. So it should of cleared by now? That's what I was thinking see. :/. Many thanks. |
RRS Daz Member Since: 23 Jan 2012 Location: Yorkshire Posts: 797 ![]() |
If there was water in the diesel would that come out with use or would it need draining?
hi guys, sorry to change the subject. where are the glow plugs located on a range rover sport 2.7 td6? many thanks. |
Does this help? Apparently they are barstewards to get out without breaking. |
