Home > Maintenance & Modifications > 2007 tdv6 timing belt guidance |
Rsdave137 Member Since: 26 Jun 2013 Location: Lancashire Posts: 44 |
Hello everyone
Mon Oct 14 2013 7:40pm |
Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 289 |
7 years or 105,000 miles
Mon Oct 14 2013 8:02pm |
Thankyou will do |
Mon Oct 14 2013 8:18pm |
Had many prices on replacing timing belt
Wed Oct 16 2013 8:12pm |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4417 |
Have to echo what Steve, above has already said.
Wed Oct 16 2013 8:24pm |
Graz Member Since: 22 Apr 2013 Location: Essex Posts: 104 |
That's cheap. Down here the best price I had for service and belts was £712 at an Indy and the most was £1,200 |
Wed Oct 16 2013 8:25pm |
Hi, just booked car in at local landrover workshop for timing belt replacement
Wed Oct 30 2013 8:22pm |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
On your year of car its a big YES to change the Oil Pump casing.... read these posts it will give you nightmares..
Wed Oct 30 2013 8:39pm |
Thankyou |
Wed Oct 30 2013 8:51pm |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 |
Just picking up on the timing case question. I have a 2005 2.7V6. I am preparing to do the cambelts shortly, but is the housing ok on these earlier engines?
Thu Jan 09 2014 10:56am |
Check on your service book, you may well find that the rear belt was done under the HPFP recall, In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Thu Jan 09 2014 12:58pm |
Recall Ref:
Thu Jan 09 2014 1:27pm |
2005 models (and 2006) oil pumps are fine. HPFP recall was only on EU4 engines |
Thu Jan 09 2014 3:18pm |
Brilliant, thanks.
Fri Jan 10 2014 9:11am |
