![]() | Home > Maintenance & Modifications > 2007 tdv6 timing belt guidance |
Rsdave137 Member Since: 26 Jun 2013 Location: Lancashire Posts: 44 ![]() ![]() ![]() |
Hello everyone
Advanced Factors Site Sponsor Member Since: 26 Apr 2013 Location: Southampton Posts: 289 ![]() ![]() |
7 years or 105,000 miles
Thankyou will do |
Had many prices on replacing timing belt
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4449 ![]() ![]() ![]() |
Have to echo what Steve, above has already said.
Graz Member Since: 22 Apr 2013 Location: Essex Posts: 104 ![]() ![]() |
That's cheap. Down here the best price I had for service and belts was £712 at an Indy and the most was £1,200 |
Hi, just booked car in at local landrover workshop for timing belt replacement
On your year of car its a big YES to change the Oil Pump casing.... read these posts it will give you nightmares..
Thankyou |
Black Bess Member Since: 09 Sep 2013 Location: Lincolnshire Posts: 245 ![]() ![]() ![]() |
Just picking up on the timing case question. I have a 2005 2.7V6. I am preparing to do the cambelts shortly, but is the housing ok on these earlier engines?
Check on your service book, you may well find that the rear belt was done under the HPFP recall, In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Recall Ref:
2005 models (and 2006) oil pumps are fine. HPFP recall was only on EU4 engines ![]() |
Brilliant, thanks.
