Home > Technical > Suspension leaning lower on one corner |
sellick Member Since: 26 Jul 2013 Location: Bath Posts: 47 |
I'm sure someone will be along to correct me soon, but it could be a leaking air bag on that corner? Can you hear any leaks? Have a search, seen a few topics like this! |
Sat Sep 07 2013 12:52pm |
DC_Supercharged Member Since: 14 Aug 2013 Location: Warwickshire Posts: 27 |
Cant hear any leaks - the car raises up fine with no dash lights on |
Sat Sep 07 2013 12:53pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
More likely to be a problem with the rear EAS valve block rather than a leaking air bag. 2012 SDV6 - it's missing a couple of cylinders
Sat Sep 07 2013 12:54pm |
Could it be a height sensor? |
Sat Sep 07 2013 12:59pm |
Will a diagnostic check bring up a possible fault |
Sat Sep 07 2013 1:03pm |
A diagnostic check will throw up a code, but it doesn't necessarily pinpoint the problem. I think you can sometimes tell if it's a dodgy height sensor by looking at the 4x4 info screen and seeing if the bars above any of the wheels are red. Is it constantly low or does it just go down overnight? |
Sat Sep 07 2013 1:32pm |
I'll check tonight |
Sat Sep 07 2013 2:20pm |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
DC_Supercharged
Sat Sep 07 2013 2:33pm |
Hi I think your right - it goes down overnight - I just drove a few miles after raising it then putting it in access mode - it's level at the moment |
Sat Sep 07 2013 2:48pm |
Could it be a leaking air bag?
Sat Sep 07 2013 3:09pm |
Do you know what the correct ride height measurements are and do you know if the face lifted 2010 on models were different.
Sat Sep 07 2013 3:13pm |
There is no correct ride height each car is slightly different thats why you need to measure the two rear corners and then adjust it until its level. You can have a few different set levels if you want to as long as you can write the settings to the RHCM, some guys on the D3 forum use this method Flack |
Sat Sep 07 2013 3:56pm |
Can the airbag leak be fixed or is it gonna be a new airbag? How much are these?
Sat Sep 07 2013 4:25pm |
You can change just the air bag or the whole leg with new bag.
Sat Sep 07 2013 8:03pm |
