Home > Technical > Suspension leaning lower on one corner
DC_Supercharged
Hey guys - my sport is sitting lower - drivers side rear - in access mode, what could be causing this to happen? What parts could be faulty? Any help much appreciated.
Post #394174 Sat Sep 07 2013 12:46pm
sellick
I'm sure someone will be along to correct me soon, but it could be a leaking air bag on that corner? Can you hear any leaks? Have a search, seen a few topics like this!
Post #394176 Sat Sep 07 2013 12:52pm
DC_Supercharged
Cant hear any leaks - the car raises up fine with no dash lights on
Post #394177 Sat Sep 07 2013 12:53pm
More likely to be a problem with the rear EAS valve block rather than a leaking air bag. 2012 SDV6 - it's missing a couple of cylinders
Post #394178 Sat Sep 07 2013 12:54pm
DC_Supercharged
Could it be a height sensor?
Post #394180 Sat Sep 07 2013 12:59pm
DC_Supercharged
Will a diagnostic check bring up a possible fault
Post #394181 Sat Sep 07 2013 1:03pm
sellick
A diagnostic check will throw up a code, but it doesn't necessarily pinpoint the problem. I think you can sometimes tell if it's a dodgy height sensor by looking at the 4x4 info screen and seeing if the bars above any of the wheels are red. Is it constantly low or does it just go down overnight?
Post #394189 Sat Sep 07 2013 1:32pm
DC_Supercharged
I'll check tonight
Post #394196 Sat Sep 07 2013 2:20pm
flack
DC_Supercharged
You need to have the car on level ground and take a measurement from the top of the wheel arch to the center of the wheel hub and see what the difference is to the other side, is it showing it lower on the 4x4 info screen, it could be a dodgy failing sensor or just recalibrating.
Flack Thumbs Up
Post #394199 Sat Sep 07 2013 2:33pm
DC_Supercharged
Hi I think your right - it goes down overnight - I just drove a few miles after raising it then putting it in access mode - it's level at the moment
Post #394200 Sat Sep 07 2013 2:48pm
SRE
Spain
Could it be a leaking air bag?
Cheapest way to check, raise car to max (off Road) and spray the air bag with lots of soapy water and look for bubbles. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #394202 Sat Sep 07 2013 3:09pm
SRE
Spain
Maybe a question for Flack
Do you know what the correct ride height measurements are and do you know if the face lifted 2010 on models were different.
I only ask, as it looks like the later models maybe ride a tad lower......then again it could be my eyesight. Whistle In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #394203 Sat Sep 07 2013 3:13pm
flack
Quote:
Maybe a question for Flack Report post
There is no correct ride height each car is slightly different thats why you need to measure the two rear corners and then adjust it until its level.
You can have a few different set levels if you want to as long as you can write the settings to the RHCM, some guys on the D3 forum use this method
Flack Thumbs Up
Post #394207 Sat Sep 07 2013 3:56pm
DC_Supercharged
Can the airbag leak be fixed or is it gonna be a new airbag? How much are these?
I looked at the 4x4 info on the screen and there were two red lines above the rear wheels - does this mean height sensor fault?
Post #394212 Sat Sep 07 2013 4:25pm
flack
You can change just the air bag or the whole leg with new bag.
No the red lines are normal as long as they are both level front and rear, if one is lower than the other then there is a problem if the car is on level ground.
Flack Thumbs Up
Post #394249 Sat Sep 07 2013 8:03pm
