![]() | Home > General > 'Pulsing' when engine braking |
Strange indeed, and certainly not the norm. 2x TDV6. SE and HSE. Both returned to sender with issues👀
GSJordan Member Since: 16 Jul 2013 Location: Manchester, UK Posts: 12 ![]() ![]() |
I've just taken it out for a quick drive again now, and it is still doing it, albeit very gently - If you just slightly depress the accelerator it stops doing it, as well as if you knock it into Neutral. How can I check whether the gearbox software needs updating? Gary RRS 2006 4.2 V8 Supercharged Bonnati Grey - Full Overfinch Supersports Kit |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
Does the rev counter show any movement? Almost sounds like the gearbox changing gear on a trailing throttle...
CUCO Member Since: 02 Jun 2011 Location: Spain & Oleee!!! Posts: 59 ![]() ![]() |
are you going with cruise control on??? it tends to have similar behaviour when driving down a decline.
warped disk? RRS gone
@ RRSTDV8: No movement on the rev counter no (unless it's that small it isn't registering - it is only slight but I can notice it now). It's not changing up and down hunting for a gear. I only bought the car a few days ago so not aware of any gearbox oil change - I was lead to believe these were 'lifetime' items though I'm not sure they should be..!
Yes sorry I missed that bit about Neutral.
Could be a torque converter getting tired or a problem with the lock-up clutch perhaps.
*UPDATE*
PS. Anyone in the Manchester area want to take it for a drive and prove I'm not going insane? It's driving me nuts now! |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 ![]() |
Having the gearbox reset from adaptive would be my first step to see if that cures it.. as you have said you have only had a short while and the old owners driving habits will still be logged..
Think I agree with the suggestions about a possible TC problem and the first step to try is clearing the gearbox adaptations. Here's what the IID Tool manual has to say about the latter:
I need to do that. Previous owner of the barge must have driven everywhere in Daisy mode and gear changes are way off where I would like plus incredibly slow to react when approaching junction or roundabout. My guess is kick down never been used and manual changes are order of the day |
@Paddi
