Home > General > 'Pulsing' when engine braking |
simple1 Member Since: 15 Jan 2006 Location: Somerset Posts: 1657 |
Strange indeed, and certainly not the norm. 2x TDV6. SE and HSE. Both returned to sender with issues👀
Tue Aug 06 2013 9:49pm |
GSJordan Member Since: 16 Jul 2013 Location: Manchester, UK Posts: 12 |
I've just taken it out for a quick drive again now, and it is still doing it, albeit very gently - If you just slightly depress the accelerator it stops doing it, as well as if you knock it into Neutral. How can I check whether the gearbox software needs updating? Gary RRS 2006 4.2 V8 Supercharged Bonnati Grey - Full Overfinch Supersports Kit |
Tue Aug 06 2013 10:32pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8976 |
Does the rev counter show any movement? Almost sounds like the gearbox changing gear on a trailing throttle...
Tue Aug 06 2013 11:14pm |
CUCO Member Since: 02 Jun 2011 Location: Spain & Oleee!!! Posts: 59 |
are you going with cruise control on??? it tends to have similar behaviour when driving down a decline.
Wed Aug 07 2013 1:44pm |
warped disk? RRS gone
Wed Aug 07 2013 1:48pm |
@ RRSTDV8: No movement on the rev counter no (unless it's that small it isn't registering - it is only slight but I can notice it now). It's not changing up and down hunting for a gear. I only bought the car a few days ago so not aware of any gearbox oil change - I was lead to believe these were 'lifetime' items though I'm not sure they should be..!
Thu Aug 08 2013 6:31pm |
Yes sorry I missed that bit about Neutral.
Fri Aug 09 2013 8:09am |
Could be a torque converter getting tired or a problem with the lock-up clutch perhaps.
Fri Aug 09 2013 9:36am |
*UPDATE*
Fri Aug 09 2013 11:40am |
PS. Anyone in the Manchester area want to take it for a drive and prove I'm not going insane? It's driving me nuts now! RRS 2006 4.2 V8 Supercharged
Fri Aug 09 2013 11:43am |
flack Member Since: 24 Feb 2013 Location: Preston Posts: 379 |
Having the gearbox reset from adaptive would be my first step to see if that cures it.. as you have said you have only had a short while and the old owners driving habits will still be logged..
Fri Aug 09 2013 12:21pm |
Think I agree with the suggestions about a possible TC problem and the first step to try is clearing the gearbox adaptations. Here's what the IID Tool manual has to say about the latter:
Fri Aug 09 2013 12:45pm |
I need to do that. Previous owner of the barge must have driven everywhere in Daisy mode and gear changes are way off where I would like plus incredibly slow to react when approaching junction or roundabout. My guess is kick down never been used and manual changes are order of the day 2x TDV6. SE and HSE. Both returned to sender with issues👀
Fri Aug 09 2013 2:05pm |
@Paddi
Fri Aug 09 2013 3:26pm |
