Home > Technical > Engine Sound |
SONYBOY Member Since: 22 Dec 2010 Location: East Of England Posts: 70 |
hi all,just noticed last day or so,when I rev the engine slightly it makes a type hissing sound from engine not a puring sound as normal...? any ideas,plus today the battery was flat....turn the key -tick tick & dash lights flicker....any info would be great please....have not had these problems b4. 2007 reg sport 2007 COOLRRS |
Sun Jun 30 2013 7:13pm |
its like a whirling sound,it aint right I know that much,looked up on YT,and there videos of them there with same sounds....I don't want to use the car till sorted..... 2007 COOLRRS |
Sun Jun 30 2013 9:10pm |
hi, no I haven't,...ive been told why my battery went flat is cause the handbrake light might of been left on all nite,....
Mon Jul 01 2013 11:20pm |
if it whines still is it ok to use ???,don't like to,but if I have to will there e damage ??? 2007 COOLRRS |
Mon Jul 01 2013 11:22pm |
Meccles Member Since: 06 Aug 2011 Location: QLD Posts: 152 |
Me I just call roadside assistance and they come with a flatbed and take it away Never in it long enough to either put it in Drive or put the hand brake on! Handbrake though, many in OZ never use it due to issues with EPB failure due to dust/dirt etc SWMBO owns this car I get to drive occasionally |
Tue Jul 02 2013 11:32am |
CUCO Member Since: 02 Jun 2011 Location: Spain & Oleee!!! Posts: 59 |
is a "Dyson" sound?
Tue Jul 02 2013 11:45am |
To be honest, without us all second guessing what the problem might be, i'd suggest calling out a recovery service if you are a member of one and ask them to check it out first, if your not a member, then shame on you You should have a membership of some sort owning a RRS.
Tue Jul 02 2013 12:40pm |
hi, ive looked it to it more slightly ,when I have parked it up,ive put it in to "P" on gear lever....and pit handbrake on.....! But the handbrake light hasn't gone off !!! (so am I right ) it should go off auto after so many minutes ???....[/b] 2007 COOLRRS |
Wed Jul 03 2013 7:41pm |
The handbrake light should go off when you switch off the ignition. |
Wed Jul 03 2013 7:44pm |
thank you,thats another thing ive got to look into.....wot would I do f I hadn't got your help Guys.... 2007 COOLRRS |
Wed Jul 03 2013 8:22pm |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 |
I doubt that the handbrake light on the dash would cause the battery to run flat. More likely the battery or alternator is on its way out. The handbrake light should go out approx 15 minutes after the car has been locked and it has gone into sleep mode.
Sat Jul 13 2013 1:45am |
