![]() | Home > Technical > Engine Sound |
SONYBOY Member Since: 22 Dec 2010 Location: East Of England Posts: 70 ![]() ![]() ![]() |
hi all,just noticed last day or so,when I rev the engine slightly it makes a type hissing sound from engine not a puring sound as normal...? any ideas,plus today the battery was flat....turn the key -tick tick & dash lights flicker....any info would be great please....have not had these problems b4. 2007 reg sport |
its like a whirling sound,it aint right I know that much,looked up on YT,and there videos of them there with same sounds....I don't want to use the car till sorted..... 2007 COOLRRS |
hi, no I haven't,...ive been told why my battery went flat is cause the handbrake light might of been left on all nite,....
if it whines still is it ok to use ???,don't like to,but if I have to will there e damage ??? 2007 COOLRRS |
Meccles Member Since: 06 Aug 2011 Location: QLD Posts: 152 ![]() ![]() ![]() |
Me I just call roadside assistance and they come with a flatbed and take it away |
CUCO Member Since: 02 Jun 2011 Location: Spain & Oleee!!! Posts: 59 ![]() ![]() |
is a "Dyson" sound?
To be honest, without us all second guessing what the problem might be, i'd suggest calling out a recovery service if you are a member of one and ask them to check it out first, if your not a member, then shame on you |
hi, ive looked it to it more slightly ,when I have parked it up,ive put it in to "P" on gear lever....and pit handbrake on.....! But the handbrake light hasn't gone off !!! (so am I right ) it should go off auto after so many minutes ???....[/b] 2007 COOLRRS |
The handbrake light should go off when you switch off the ignition. |
thank you,thats another thing ive got to look into.....wot would I do f I hadn't got your help Guys.... |
kav1187 Member Since: 04 Apr 2012 Location: SX Posts: 307 ![]() ![]() ![]() |
I doubt that the handbrake light on the dash would cause the battery to run flat. More likely the battery or alternator is on its way out. The handbrake light should go out approx 15 minutes after the car has been locked and it has gone into sleep mode.
