Home > Faults & Fixes > Roof Leak
cliftonvilla
Roof Leak
After heavy rain I get a steady drip from the light unit set in the roof lining near the rear view mirror. My RRS is a 2010 facelift model with a factory fitted sunroof, has anyone experienced a leak in this area and f so did you manage to find the source. I have looked for anything obvious but can't see anything that jumps out.
Thanks for any help
Clifton Vlla 2010MY Overfinch
Post #383242 Thu May 16 2013 1:04pm
You'll probably find it's the roof drains that have got clogged up and caused the water to back up and drip down.
Similar thread here Thumbs Up
http://www.rrsport.co.uk/forum/topic29377....roof+drain ON THE WAY: BMW F21 M140i
Post #383243 Thu May 16 2013 1:08pm
cliftonvilla
Thanks for the reply/suggestion I'll have the drain tubes blown out with compressed air and see how it goes.
Clifton Villa 2010MY Overfinch
Post #383292 Fri May 17 2013 6:58am
I think you need to thread something down them, not air
Wink
Post #383293 Fri May 17 2013 6:59am
cliftonvilla
Okay thanks, will try that to.
Post #383297 Fri May 17 2013 7:30am
SRE
Spain
If you use air and blow the drain tubes off, then you will have a problem In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #383300 Fri May 17 2013 7:59am
